Common solar PV questions/mistakes
"Torque it or maybe cause a fire if you don't", and "torque it and forget it"! Those were sayings taught in the apprenticeship program I went through years ago. But that was because of that nasty aluminum wiring. But it still applies to copper.DanS26 said:You guys missed a big one.........."Why do I need a torque screwdriver, I know how to tighten a connection"lol
Yes.....because over-tight is just as bad as under-tight. I have smashed #12 copper to where it breaks off at the connection....not good.23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011
- 230 Forum & Website
