Inverter Gen Max size
JRHill
Registered Users Posts: 515 ✭✭✭✭
A previous post has me wondering: from my limited sight it seems inverter generators max out around 7kW. So all these 12, 20, 25 kw monsters are just spinning at 1800 or 3600 RPM? Or are any of these monsters inverter gensets?
Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Harbor Freight has an 11.5 and a 9.5
https://www.harborfreight.com/generators-engines/generators/inverter-generators.html
Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
- 230 Forum & Website
