Schneider Electric XW+ system, added Discovery Helios lithium batteries, AGS question
cbelk
cbelk Registered Users, Users Awaiting Email Confirmation Posts: 1
We have Schneider Electric XW+ system and just switched from lead acid to lithium batteries.  We have insight home to monitor the system and purchased the Lynx II to communicate between the batteries and the Schneider Electric system.  Everything seems to be working well, except the installation instructions do not cover AGS settings.  When I use my insight cloud to change the SOC trigger to 20% it will only let me go as low as 40%.  I sized the battery bank based on being able to use down to 20%, and that is a conservative setting.  I am wondering if there is any override for this setting in the Insight.
  • Graham Parkinson
    Graham Parkinson Registered Users Posts: 197 ✭✭✭
    I have Discover Element batteries and the AGS but I don't use SOC generator start so haven't any direct knowledge (yet).
    Have you tried using Insight Local (LAN) or Insight Direct (Wifi) - you might see different options.
    The AGS is funny, for some settings you need to be in AGS standby mode.
    Offgrid in cloudy PNW
    Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries (with integrated heating), Slimline enclosure, Lynk II, AGS, H650,  H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
    Dave Angelini Solar Expert Posts: 7,119 ✭✭✭✭✭✭
    XW+ does not have the same capability in several configuration settings as XW pro.  You may have to live with it.
