Current Cost of Adding Whole House Generator
I found a Kohler 14kW and 200A ATS is about $6,000. That means $9,000 was the cost for rebar, concrete, gas line, electrical wire, and the labor to connect the gas and to connect the generator to the ATS and the panel. Am I out of line for thinking $9,000 is excessive, and that it probably should be closer to $2,000, which would be about 4 hours for the plumber at $200 per hour and 4 hours for the electrician at $200 per hour, knowing full well that $200 per hour is probably high?
TIA
Current System:
Nothing yet - laying the groundwork
Previous System (2000 - 2019)
48v Off-Grid
Modules: 5.395 kW:
(16) Kyocera KC130TM
(12) Kyocera KD-210GX-LPU
(3) Kyocera KU265-6MCA
Batteries:
(24) Trojan Solar SPRE 02 1255
Racks:
(2) Zomework trackers (KC130TM modules, 8 per tracker, landscape position) - facing due south
(1) Unirac ground mounted fixed rack (all KD210 modules, landscape position) - facing slightly southwest
(1) Unirac roof mounted fixed rack (all KU265 modules, landscape postion) - facing due south
Inverters:
(2) Trace SW5548
Charge Controllers:
(1) Outback MX60 - for (16) KC130 modules
(1) Flexmax60 - for (12) KD210 modules
(1) Flexmax60 - for (3) KU265 modules
Generator:
(1) Kohler 14RESA propane
That's a pretty nice system! Your system information already shows: Generator: (1) Kohler 14RESA propane so I'm confused. And some of your equipment is REALLY old - Congratulations!
You don't say where you live so its pretty hard to answer your question. Location, location, location....
Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat. -
Hi, Well, I need to remove that system from my profile. I sold that house, and before selling it we upgraded everything in 2018. This is why I laugh at people who tell me they will save money by putting solar on their houses - definitely not true. But, I will do it again because it works, it works well, and I like the freedom it provides.
I now live in a house in the Black Hills area of WY & SD without any PV at the time. But, I am currently completing a major top to bottom, inside & outside, remodel. This is why I am considering the generator at this time - dig the trenches from the house to the future generator location while the landscaping is in process of being redone.Current System:
48v Off-Grid
Modules: 5.395 kW:
Batteries:
Racks:
Inverters:
(2) Trace SW5548
Charge Controllers:
Generator:
I know the area. I guess it probably depends how hungry those tradesmen are at the time of 'bidding' the job. And also if you want this done before the cold winds blow and that time is getting short. Also the remoteness of your project.
Where we are if I call a tradesman (State licensed with all the i's and t's) they charge full rate even for driving because, as I was told if they "weren't on the road they'd be making full rate at a closer place". Ya can't get much more clear than that.
I keep hearing the Generac add in N Nevada for $125 a month installed.
Probably for the rest of your life. 😉
Costco has good deals also!"we go where power lines don't" Sierra Nevada mountain area
"But, I will do it again because it works, it works well, and I like the freedom it provides."
@pvoffgrid , I have a question for you? You are heading into a new from scratch system at a new place. Based upon your past experience)+) and starting fresh, what are you leaning toward? You are one who understands the need for load calculations, location/exposure, choosing appliances and making adjustments to life vs just flipping a switch, etc. The equipment market has had some fall outs, models cancelled (but some new equipment introduced) and so on.
If you could build your dream system, and maybe that's what you are doing, what are you looking at? Doing it yourself or reliant on a local business?
I hope this doesn't seem snoopy. I am curious because of the range of experiences some people have. Some folk have nothing but bad to say when relying on a mass vendor. Then there are those who have understanding even if they hired out. But ya don't hear about them quite as much because of lack of problems. What's your idea of a problem free and minimum maintenance system?Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat. -
Yes, I am heading into a new from scratch system. I am going to go slow and get this remodel well behind me before moving into a new PV system, and this new PV system will be a combination grid-tied/off-grid system. I will not do it myself but I will act as a GC to the extent I can. This is because I have found since 2000 most PV companies do their best to make PV sound like rocket science. It is not...it is pretty straight forward based on my attendance at the school of hard knocks.
Every house in the neighborhood I lived in was PV-powered with batteries and generators due to the local Indian Pueblo refusing to allow the power lines to be extended two miles into our neighborhood. But, that did not matter to us as PV worked beautifully, with some hiccups of course that were easily solved. Let me start with the description of the houses in the neighborhood. $600k USD and up. 3 - 8 bedrooms. 3 - 5 bathrooms. 1 - 3 stories. 1,600 sq ft to 8,500 sq ft. Log home. Straw bale. 2x6 stick built. ICF forms. PV size ranged from 1.9 kW, 1,125 aH battery bank with a 11 kW Kohler propane generator (my initial size for my 3,200 sq ft 3 bed, 3 bath, 2 story home with out buildings, a full woodshop, electric dryer, and 5-car garage) to recently 15kW (prices have decreased since 2000).
What we learned is at 1.9kW we had to watch our power usage. At 2.4 it was less watching, and at 3.6 it was minimal issues - occasionally a problem. Getting into the 4 kW range - no issues with power. 5kW and above you asked yourself was the power truly coming from the sun? A 5kW system will power the majority of homes without issues, if there is no air conditioning (refrigerated air), no swimming pools, etc. So, doing a load calculation is fun to do but not necessary. What I also learned was that friends and coworkers who lived in the city were being sold 8kW - 12kW grid-tied systems if they had pools and AC; that just confirmed to me a load calculation was not needed. And now, with prices low, just go buy a 12kW - 20kW system. Generator size? we used a 11kW Kohler for 18 years and when we replaced it we went with the Kohler 14kW. Our good friends had a Ford 18kW (maybe a 20kW?) and he always stated it was overkill for charging his batteries. Remember, we were not connected to the grid but I look at it this way. My 11kW powered my house by itself without any issues when we used it like that on occasion.Current System:
48v Off-Grid
Modules: 5.395 kW:
Batteries:
Racks:
Inverters:
(2) Trace SW5548
Charge Controllers:
Generator:
Lessons Learned: Put your batteries & inverters in the garage or right next to the house. We put ours in a separate building down a slope Never ever again - if we needed to reset the inverters, check the generator, etc it was always raining, windy, muddy, snowy, cold. I hated that aspect. Our neighbors just went into their garages - lol. Leave enough space above the batteries to add water easily if you have lead-acid batteries. But, today should not be a problem as the Lithium batteries are so inexpensive now lead-acid would be a huge step backwards. My personal preference is the PV modules should be ground-mounted but that is also location-dependent. I just know that when it snowed I had my panels cleared within 15 minutes but my neighbors would often have snow-covered panels all day long.
I hope this answers some of your questions but let me know if you have some, or if I confused things.Current System:
48v Off-Grid
Modules: 5.395 kW:
Batteries:
Racks:
Inverters:
(2) Trace SW5548
Charge Controllers:
Generator:
Nope. I appreciate your experience. I hope you can find the installers who have experience with the equipment YOU have chosen.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
Tying into a 200A service with an automatic transfer switch can be a full day or two of work, plus heavy gauge copper wiring isn’t cheap right now.
If you live in a state that is supportive of solar (Virginia) and can do your own work and have an agreeable electric company (Dominion Power), installing solar is well worth it. Our county will do the inspections that the electric company requires and bingo, your golden. The permit and inspection process is fairly straightforward for the homeowner. Its the contractors that have to jump through more hoops and are subject to less leniency/understanding during inspections.All the resources and equipment you need can be purchased by the homeowner now. Iron Ridge has design tools. You can buy previous generation new enphase/sunpower micros that are under warranty for $50-100 each. But those won't let you micro-grid, which is no big deal here as we only lose power once or twice a year for a day or so. I have a plug in generator to get us by. You can do all the installation commissioning for enphase on their app. If you have the land, then yes, ground mounts are the way to go.Our system has paid for it self and then some now. Just don't design it to make money selling it back. The wholesale rate is around $.04 and the retail purchase rate for power in my area is about $.125. Doesn't make sense to make too much. We get zero'd out once a year, so for the entire year you get to feed and take from the grid. Not like some states like Hawaii that zero you out each day.My brother is an off-grid'er in the middle of a town. He spends a lot of time with battery maintenance and inverter configuration and so on. No thanks. I just check my app to make sure all the panels are producing. Very low maintenance/intervention. The installer companies have to make a profit which is why the pay back period is so long. Ours was about 6 years. Our electric bill is about $250-$300/year. Prior to solar that was monthly cost in the summer months.Thats my 2 cents worth. :-)Pat9000+W grid tied IQ7 22 panel rooftop and 6 panel ground combination with 1 additional IQ7 connected to 500W wind turbine+200w solar+2 IQ7s with 300W+600W on the RV grid tied when it's in the driveway.
You might price out a couple more installers. Generator hookup costs vary a lot by region and code requirements, so getting a few quotes can tell you if $9k is normal in your area or if someone’s charging too much.
