Grid-Tie Inverters Question
Does anyone know of a manufacturer who makes larger inverters (15-20KW) that can be tied into using a generator to product power for net metering and doesn't require solar panel or any loads to run the system. Ive searched for days and all I come up with is systems that require solar panels to do the net metering. I'm not trying to power any loads, just want to do the net metering. I cant believe that there are no commercially available grid-tie inverters that simply take either AC or DC and send it back to the grid via net metering.
  • Suhaib
    Suhaib Registered Users Posts: 1
    When you synchronize utility supply power (grid) with a solar inverter in a grid-tied system, the reason why the load is primarily supplied from the solar inverter first—even though the utility system is much larger and stronger
  • littleharbor2
    It's going to cost you a lot more in fuel than you're ever going to get back from the power company
  • JRHill
    JRHill Registered Users Posts: 487 ✭✭✭✭
    I can visualize a solution to the question. What I can't visualize is a generator running for whatever reason and you decide that, "Well, as long as its running, I might as well feed power into the grid"?
    Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
