Can I use this little Victron charge controller with this setup?
softdown
softdown Solar Expert Posts: 3,968 ✭✭✭✭
Bought a couple 48V 20A 100V Victrons last year. Unsure what I was thinking.
Wanting to use four 190 watt solar panels with one controller. They put out ~40. volts in optimal conditions.
Think I’ll point these panels to the east at ~ 20 degrees. Have steel racks made.
Just need more solar in July and August - 8 fridges and freezers. #PreparedPrepper
  • softdown
  • MikesSolarGarage
    MikesSolarGarage Registered Users Posts: 3
    It should be fine as long as you don't live in a very cold climate.  Cold sunny days increase a panels output.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,142 ✭✭✭✭✭
    Battery bank voltage?
  • softdown
    Gets to -20F here. And the eastern orientation amplifies that challenge. Oh well, I have two and they are pretty cheap. Probably why this penny pincher pounced.
  • softdown
    Been having sunny weather lately. Sitting at 53.2 volts at 2:12pm with some clouds.
  • softdown
    Adding panels is maybe 75% of the work of doing an entire system. Anxiety when voltmeter read 0 volts - due to being in wrong voltage range. Plus combiner box was missing the fuse for some reason. Unbelievable amount of work involved.
