custom one-axis ground mount
Is the gateing/fencing to keep stock out or in?
The fence is to keep elk and horses out. The far side is the steep rocky bank of an arroyo. I need some rain.
I've built a board to interface a tracker with the motors and switches of a 2 axis tracker. Its not high voltage but will interface with relays to move larger motors. I haven't installed it yet but made 10 of them since the minimum buy is usually 10. I use the SBE solar tracker. Its not bad, gets confused some times but that's why I built the switch interface to return it back to morning home or turn it parallel to the wind. https://www.amazon.com/s/ref=bl_dp_s_web_0?ie=UTF8&search-alias=aps&field-keywords=SBESolarTech
9000+W grid tied IQ7 22 panel rooftop and 6 panel ground combination with 1 additional IQ7 connected to 500W wind turbine+200w solar+2 IQ7s with 300W+600W on the RV grid tied when it's in the driveway.
