need help with an xw4548
t00ls
Solar Expert Posts: 283 ✭✭✭✭
haven't been here for a while
I
have an XW4548 that the main logic board went bad...the amp sensor
started making the inverter think it had an F63 fault. I could wiggle
the sensor and it would start inverting again.
I
but
I tried to repair it with another coil and now it doesnt work at all
do you know where I could get one or does anyone know of someone that can fix this one
part #
200 - 0184 - 01 - 01 rev g
110 -0184 - m
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
I have a list (getting old) of inverter repair facilities...
https://forum.solar-electric.com/discussion/comment/241766#Comment_241766
If anyone has more/others, please feel free to post here and I will add them to and/or update the FAQ.
There are sellers on eBay who sell this type of stuff.
littleharbor2 said:There are sellers on eBay who sell this type of stuff.
not trying to rude or an ass...dont you think I looked there first....they dont make the xw4548 anymore and anyone who kept PCBs didnt keep the main logic board
the current meter coil went bad on mine...like the solder connections werent connected
I have a guy that might be able to fix it, but he usually does TVs and such...didnt even know what I had...just told him what needed fixed
doing a google search for the specific part # got no results...I want to try and contact robin at midnite...he was the enigineer that worked on these when they first came out...I bought this one in 2008
I have a few more places to try...but havent come up on one yet
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw ) -
Not going to assume what you did or didn't do first. Many people benefit from these conversations on the forum and maybe others who didn't know this will learn something.t00ls said:littleharbor2 said:There are sellers on eBay who sell this type of stuff.
I have a few more places to try...but havent come up on one yet2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Did you ever get her working again ?
hybrid: two xw6848 pro with four mppt60, 12 kw pv
17 cell 280ah LiFePO4 storage 14 kw (now at 3 banks) total 40 kw
gridtie: sunny boy sma 2x 5k
gridtie: fronius ag5100 two 5k (only one with 1.5k left) running on fumes
Gateway / Insight Local -
tampasolar said:Did you ever get her working again ?
nope...bought a XWPRO 6848 for $1500 brand new in the box (had a lot of dust on it) got it through ebay....because the XWline is being discontinued and being replaced by the pulse...going to look at the user manual in a few minutes( I dont own a pulse)
I still would like to find that board12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw ) -
I got me a spare for $1400
