Schneider electric Conext SW service guide (maintenance manual)
HH2k
Registered Users Posts: 5 ✭✭
Hello everybody,
i am new to the forum
i have two faulty units of Schneider electric Conext SW 2524 inverter/charger, And no licensed maintenance available in my country for such units.
So i need the service guide (maintenance manual) urgently please.
can anyone provide me with its pdf ?
There is not one ! CSW2524 was replaced with CSW4024. Repair shops scavenge parts from damaged units for repair. New parts are only available in warranty. A warranty repair, which is very rare, is often a new unit.
Can you, or someone you know, replace PCB's ?"we go where power lines don't" Sierra Nevada mountain area
Dave Angelini said:
if there is service guide for CSW4024, it will be useful, i think boards are same except some ships or so.There is not one ! CSW2524 was replaced with CSW4024.
i need service manual for any CSW unit 2524. or 4024, or 4048
yes correct i am in EgyptBB. said:
that's why i said (no licensed maintenance available in my country for such units)
Schneider electric available here but not working in solar at all, i brought these units with me from another country
Most large Electronics companies do not make service manuals for use outside their company. This has been true for many decades."we go where power lines don't" Sierra Nevada mountain area
yes you are correct, but usually it is available (somehow),Dave Angelini said:Most large Electronics companies do not make service manuals for use outside their company. This has been true for many decades.
because i found on the web the service guide for the bigger family (Conext XW). -
I was distantly involved in XW development and back in the early 2003 when it was proposed, I remember hearing that the US department of defense grant required a service manual for printed circuit field repair.
When XW became available for sale by 2006 I was actively involved. It was rare that that it was economical to do field repair. There were very low failure rates and even lower levels of people who could use a grounded wrist strap for field PCB repair. Far less expensive to replace the XW than repair it.
You might also find the XW field repair video on YouTube. It is board level repair and will not help much unless you have PCB's.
CSW is just not built to last and the warranty/price tells the story. A registered XW is 10 years and a CSW is 2 years.
"Somehow" I hope you find what you are looking for. BTW, what is specifically wrong?"we go where power lines don't" Sierra Nevada mountain area
Thank you dave,
i just tried to save these units because they are new, i brought 6 units 2 of them was damaged due to bad transportation,
i talked to schneider Egypt but these models are not available in Egypt at all so they will send abroad to repair, too much cost,
and any electronics technician will need scheme or maintenance guide to diagnose the fault,
but it seems that i lost them finally.
Thank you anyway -
The inverter stays on the opening screen and does not turn on
shneider conext cl 20000e
