Kohler 20 kw nightmare
mfrausto73
mfrausto73 Registered Users Posts: 5 ✭✭
Well I bought a Kohler 20 kw generator last year 2023 and it has been a pain in my rear. It trips my afci breakers. Everything imaginable has been done to figure out what is wrong. It happens when the transfer switch turns to generator power. Does anyone else out there have this issue.
    Dave Angelini Solar Expert Posts: 7,115 ✭✭✭✭✭✭
    Have you replaced the AFCI with a different make device? The more info you give the better result.
    Are you offgrid? Who installed? Where are you? Tell us what is imaginable that has been done?
  • DanS26
    DanS26 Solar Expert Posts: 274 ✭✭✭
    You are condemning the generator but the most likely culprit is the transfer switch. An arc is being sensed at the transfer switch mechanism.
    I had the same problem and the only solution was to replace the AFCI breakers.
    23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011
  • mfrausto73
    Well for starters we changed the spark plugs that made fewer afci breakers trip. Tech also updated firmware. Played with settings on generator Voltage. Checked all connections to make sure everything was nice and tight. And upgraded my afci breakers to heavy duty Eaton breakers and still they trip. Generator has brand new spark plugs now and it is brand new as well. Any advice anybody experiencing the same thing as me with my Kohler 20KW.
  • mfrausto73
    Quality generators installed my unit.
  • mfrausto73
    I am in Houston Tx.
    About 35 clients over the years using Kohler/Honda. The only problems have been the electronics being expensive. It usually fixes them for a long time. A good Genny.
    With any generator problem, it should be easy to prove with another generator. I did not see that you mentioned a rather easy test to swap out the bad unit.
    I would also try shutting down the grid first, then do the transfer if it can be done this way. Idea is
    to eliminate the grid as a source.
  • mfrausto73
    They are going to replace the transfer switch hopefully that fixes my headache of tripping afci breakers.
  • DanS26
    Still under warranty?  If so good....I had to replace AFCI breakers with standard breakers.  Not code compliant on some circuits but it was way less expensive than replacing the transfer switch.
  • JRHill
    JRHill Registered Users Posts: 521 ✭✭✭✭
    "Well for starters we changed the spark plugs that made fewer afci breakers trip."
    I am at a loss for words on that statement.
    Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
    BB. Super Moderators, Administrators Posts: 33,741 admin
    AFCI (Arc Fault Circuit Interrupters) detect an "arc fault" (sustained arcing on AC wiring) from monitoring the Radio Frequency (and other?) electrical noise on the AC lines. And one reason that folks have had problems with false AFCI trips from (for example) vacuum cleaner tripping--The brushes creating arcs can be detected by the AFCI as an "arc frequency signature".
    I am guessing that, for example, in decades past, resistors where added to some models of spark plugs to reduce AM Radio interference... Changing plugs, specially to resistor types vs non-resistor, could reduce false AFCI trips--At least a guess on my part.
    A short paper from Champion on several resistor type plugs:
    https://www.gsparkplug.com/media/wysiwyg/technical-information/champion/Champion_Resistor_EN-F-ES.pdf
    There are also "resistor plug caps" available:
    https://torqueadvisor.com/resistor-vs-non-resistor-spark-plugs/
    There are also several types of "resistor ignition cables" too:
    https://autowiringpro.com/spark-plug-wires/
    Can/does this cause AFCI false trips? Don't know for sure.
    Otherwise, people have reported that AFCI's have been damaged from power surges (lightning, high voltage power line crosses), and just "electrically noisy" generators:
    https://forums.mikeholt.com/threads/generator-causing-afcis-to-trip.137909/page
  • t00ls
    t00ls Solar Expert Posts: 283 ✭✭✭✭
    radio interference? I wonder if ferrite coils around the wiring could solve the problem
    12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
  • JRHill
    I have just had to put up and live with the interference. In a different location it would not be an issue. But where we live there are no 'powerhouse' stations, plus we live in a canyon. So any signal that gets to us is weak and so it is overwhelmed buy the small amount created by our solar. It is pretty obvious. If I merely keep the radio 20' away from any conductor and just turn up the volume so I can listen to the programming all is good. Another thing that works good is receiving a radio station over the internet (Starlink>WiFi>Cell Phone) works just fine in the house or as far as the WiFi reaches. This is especially useful when the stations reduce their signal power later in the day.
    There are specifically "lossy" Ferrites that are used to reduce interference (one computer power cables and such).
    Just Ferrites themselves and cause inductive resonance in your wiring--And that can be "bad".
    Note that DC cables typically need to be passed thru a Ferrite in +/- pairs to block conducted noise. Just passing a single + or - power cable can create too large of magnetic field and saturate the Ferrite and block its noise filtering effects.
    The AM receiver is 20 feet away from the genset and its output,  and a weak station comes in fine ?
    Run the genset when there is nothing on the radio you want to hear😉
  • JRHill
    No, not the genset. Any conductor related to the off grid system. Including buried lines or extension cords.
    Would be best if you started a thread as this is about a genset, right?
    Living offgrid is a great way to get awesome AM and HF radio reception.
     Some Hams have their stations running on battery inverters that are only charged when they are not using the radio.
  • JRHill
    Sorry Dave. I didn't mean to hijack the thread. My intent was that it's hard to resolve an interference problem that is there because of a weak signal.
