Batteries in the attic?
Yes we have installed in this type of space and it turned out to be a big hassle. Had stairs leading to a second floor utility area that was access to storage above garage and attic of entire 1-story home. The entire area was spray foamed to keep space within 4-5 degrees of interior home. After initial building review approval we installed non vented batteries and 15k inverter in this space. inspector came out and failed us, required us to build an enclosed utility room around the batteries and inverter with Type x drywall on all surfaces of the enclosed space. with doors, creating a utility closet.
Inspector could have also insisted on some venting method or a very large space as sealed batteries in failure modes need this also addressed. Just thinking of using the attic is bad enough.
Thanks for posting as it might help someone!"we go where power lines don't" Sierra Nevada mountain area
Make sure the attic space is well-ventilated, can support the battery weight, and is separated from living areas. Check local codes and manufacturer instructions for fire, spill, and temperature requirements before installing.
Thick8 said:I want to move my battery backup system into the attic. I am in the process of finishing that space as a living area but can section off part of it for the batteries. What would I need to do to make that work? venting, spill mitigation, etc. Is there a building code established for doing this?
An attic is usually a bad place for batteries. Heat kills battery life, and attics exceed safe temps in summer. Most codes require batteries to be in a conditioned space or rated enclosure.
Lead acid needs spill containment, ventilation, and corrosion resistant surfaces. Lithium needs temperature control, fire rated separation from living space, and manufacturer approved mounting. Many AHJs prohibit batteries above habitable rooms.
Check local code and manufacturer install manuals first. In most cases a utility room, garage wall, or ground level enclosure is the compliant option.
- 234 Forum & Website
