fronius IGplus 150
MOSHIKO
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
hello,
Is it possible to connect solar panels whose general power is higher than the
power of the installed converter.
For example i have a converter of the type fronius IGplus 150 capable of producing 12600w, and panels installed and connected with a power of 25000 w will the converter stop at its production capacity (12600W)?
moshiko maimonthanks
Yes it will throttle at it max AC output 12 kW per the 150 spec sheet. Max DC input is spec at 55.6 amps DC.
Your DC/AC ratio would be 1.98 which I have seen the Fronius line work without throwing a code but in my opinion a little high.
I operate at 1.50 DC/AC ratio and my Fronius inverters love it.23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011
- 230 Forum & Website
