XW pro Recharge Voltage Setting
watchdog88
Registered Users Posts: 3 ✭
I am trying to fine tune my system to make it as hands off as possible. I am running into a problem with the Recharge Voltage setting. I was assuming that the inverter would enter into a bulk charge cycle when the voltage fell below the set number. I had mine set at 51volts, and nothing happened when it fell below this setting.
XWPRO 6848 (firmware 1.11 bn49) open loop, grid tied.
Insight Local (firmware 1.18 bn41)
MPPT 100/600 (firmware 2.00 bn9)
5 kw solar DC coupled.
9 EG4LL 100a 48v Batteries
on or offgrid. There are 2 chargers in an XW system. The inverter/charger and the mppt's. More details always help."we go where power lines don't" Sierra Nevada mountain area
Apologies, I am grid tied, Grid support enabled.
Here are my current settings.
