Inverter THD
chabeck
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
My inverter is on use last legs, XW4024. Looking at a 4kw AIMS Power PICOGLF40W24V120V 24 Volt Low Frequency Pure Sine Inverter Charger but it lists,
- THD: <10% DC.
THD: <10% DCTo the best of my knowledge there is not THD with pure DC circuits. With that being said, I would be more concerned with Power Factor or Power Factor Corrected circuits being in the 95% or above range.If the inverter you posted really has a THD of 10%, I would look elsewere.Maybe the Schneider at the link below.
The inverter I use (XWP) by Schneider "waveform" is rated at less than 5% THD at rated power output. Your out of production XW4024 should be similar but you should verify."we go where power lines don't" Sierra Nevada mountain area
- 230 Forum & Website
