Off grid inverter
Feenster
Registered Users Posts: 13 ✭✭
I have an old MPPSolar PIP4048 inverter/charger. It has done well - had to be repaired once, but definitely my fault.
I am looking for a back up. It needs to have the following features: 48Vdc, MPPT voltage range of 60V to 115V (max Voc of 150V), user defined bulk voltage, Equalization, single phase 230Vac, etc.
Has any one any suggestions or recommendations please?
Just an FYI--I think Feenster is out out of Ireland--So companies/products available in Ireland/EU are probably a better fit for him.
It seems most of the 48 volt AIO units these days are high voltage models with high voltage start up limits. Can you rewire your array?
littleharbor2 said:It seems most of the 48 volt AIO units these days are high voltage models with high voltage start up limits. Can you rewire your array?Yes, I could. However, I would prefer to leave it as it is.As well as the inverter/charger, I also have another array attached to an EPEVER Solar Charger. It has the same MPPT Voltage range - 60 to 115Vdc.If I have to change one of the arrays its not the end of the world.
I see Growatt has some lower VDC input 48 volt AIO inverters
Yes, I have had a look at Growatt. I am just wondering if people have much experience with Growatt. They are relatively cheap, but what is the quality like?
I have zero experience with the brand. You should at least look up reviews and search the solar forums for any issues or praise of the brand.
I also have no experience directly but from what I gather the Growatt is at par or better than the MPP devices.
- 621 Discussion Forums/Café
