Mppt user settings
bushy20
Registered Users Posts: 4 ✭
Have 10x 1.2v 90 amp hour fully flooded nicad battries and have no specs for them.
Can anyone suggest what settings for
equalising voltage?
boost voltage?
floating charging voltage?
over-discharge voltage?
have 500w array
equalising voltage?
boost voltage?
have 500w array
This might help. You can download a users guide from this website with all the specs for their batteries.
Single Cell HC/HB NiCad battery (alcad.com)
thanks cheked it out but not much help. Have sent them same question so we c what comes back.
I see a recommended charge voltage of 1.65 volts per cell @ 18 amps. It's a start. Look up whatever you can find on NiCad batteries, online. You may find more general charging info.
Thats about where ive gotten to too. For the other settings not so shure. Still looking so thanks for that.
Best of luck to you. Maybe someone else will chime in.
Oh, and welcome to the Forum.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Hope so. Have raised voltage from presets by 2 volts so is it I raise all other presets by 2 volts across all the fields.
