Mppt user settings
bushy20
bushy20 Registered Users Posts: 4
Have 10x 1.2v 90 amp hour fully flooded nicad battries and have no specs for them.
Can anyone suggest what settings for
equalising voltage?
boost voltage?
floating charging voltage?
over-discharge voltage?
have 500w array
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,180 ✭✭✭✭✭
    This might help. You can download a users guide from this website with all the specs for their batteries.
    Single Cell HC/HB NiCad battery (alcad.com)
  • bushy20
    thanks cheked it out but not much help. Have sent them same question so we c what comes back.
  • littleharbor2
    edited July 2023 #4
    I see a recommended charge voltage of 1.65 volts per cell @ 18 amps. It's a start. Look up whatever you can find on NiCad batteries, online. You may find more general charging info.
  • bushy20
    Thats about where ive gotten to too. For the other settings not so shure. Still looking so thanks for that.
  • littleharbor2
    Best of luck to you. Maybe someone else will chime in.
    Oh, and welcome to the Forum.
  • bushy20
    Hope so. Have raised voltage from presets by 2 volts so is it I raise all other presets by 2 volts across all the fields.
