Skystream 3.7 Wind Turbines
Stanton
Registered Users Posts: 2 ✭
Skystream is back! Wind Resource LLC is manufacturing Skystream in Kansas City Missouri.
Wind Resource is producing Skystream has joined the global mission to accelerate the world's transition to sustainable energy.
We are reaching out to discover Skystream turbines owners and prospective owners to understand the need for service and Skystream replacement. Turbines and parts are available.
Let us know how we can support your renewable energy requirements.
Thanks in advance for your consideration. I look forward to speaking with you.
Best,
Dan
Dan Stanton
503-267-3238
Wind Resource LLC
Best of luck with bringing back the product.
Any chance you are going to put a "tail" on the upcoming models? Trying to keep the tower/platform absolutely level has not worked out well as the drag of the blades does not seem to be enough to keep it pointed up/down wind.
Any chance of bringing down the electronics to the base of the tower for easier servicing? Another "maintenance" issue.
Looking for Skystream service in Iowa...have tilt-up tower. Brushes have been replaced. Just quit working after 11 years...could be inverter??? Needs to be leveled as well.
Are parts available?
My unit was installed in 2009, replaced the brushes twice and now it looks like the Yaw bearing is out. It would be nice to have a parts source.
Also, the communications from turbine to a PC does not work on new PC's, it would be nice to have a software update as well. -
A local bearing industrial supply house should be able to source your bearings.
Greetings:
My name is Mark King and I inherited a house in Western Maine that has a Skystream that was installed about 15 years ago. Last year it stopped spinning, except under heavy winds (and only turns slowly). It also tripped the breaker and keeps tripping when I try and reset it.
My question, do you ever come to the Northeast to do any work? I cannot find anyone who works on them in New England.
Thanks!
Mark King
mark.a.king@maine.gov -
Hi, we are located in New Zealand and have a Skystream Turbine Serial number KA-2011-0489 230V 50 Hz which has just stopped working. Can you please tell me if there is anyone in New Zealand able to service this. We are located in Canterbury, New Zealand
Hello wlllJack7 we are located in North Canterbury just north west of Cheviot. Our Sky Stream turbine is approximately 12 years old and has just stopped working. Would be good to get in contact with as many Sky Stream owners in N.Z to work out how to get servicing and parts.
- 232 Forum & Website
