Wire connection question
All I want to do is connect 4 100 watts solar panels running 12 awg wire into a (?) 1 8 awg out that goes to charge controller. I apparently don't know the correct term for what I'm looking for. What I want is a simple screw down type connecter box. Where the 4 sets of 12 awg go into the box( don't know correct term so I'll say box) screw down on the wire for connection and 1 8 awg out with the same type screw down connection. I found car audio things like this but it's in reverse. 1 8 awg in and 4 12 awg out. Would it work in reverse? I don't want any mc4 splitters or anything like that. Just a simple screw down junction type thing.
Thanks for any help
You need a Combiner Box. With 4 (strings of) panels each string needs to be fused. If you have a 100 max Voc MPPT charge controller you could series wire all four panels, creating a single string, eliminating the need for a combiner and 8 awg wire.
I have a HQST 40 AMP 600 watt mppt controller. 12 awg would suffice for that voltage?
That is what I'll do. I'll wire them in series. Less wire,less work. Thank you. That's why I come to you guys
bgu1982 said:That is what I'll do. I'll wire them in series. Less wire,less work. Thank you. That's why I come to you guys
What is the Voc of these panels?
24 volt DC, 6.2 amps max
So that would would be 96 volts max correct. My charge controller says it's 100 voc input. Is that to close? Can the solar panels make more power than the max rating? In cold weather? -
bgu1982 said:24 volt DC, 6.2 amps max
You say 24 volt, Do you mean 24 volt nominal? Which would be to charge a 24 volt battery bank?
Usually, you can look at the information on the back of the panel and read the VMP and VOC of the panel.
No sir, it's for a 12 volt system, usually runs around 19v
SKU(s)57325BrandTHUNDERBOLT SOLARDC Volts24Accessories IncludedSAE connectorAmperage (amps)6.2 maxProduct Height1.4 In.Product Length36.5 In.Product Weight15 lb.Product Width27 In.Shipping Weight20.90 lb.Wattage (watts)100 -
Harbor freight stuff, no info available. Really sad.
In the future, I'd recommend buying from someone who will give you 'real' info about what you are buying.
Renogy having a Turkey day sale 20% off, 100 watt panels $85 delivered;
https://www.renogy.com/100-watt-12-volt-monocrystalline-solar-panel-compact-design/
Specs;Maximum Power at STC: 100W
Cell Efficiency: 22.00%
Optimum Operating Voltage (Vmp): 20.4V
Open-Circuit Voltage (Voc): 24.3V
Optimum Operating Current (Imp): 4.91A
Short-Circuit Current (Isc): 5.21A
Operating Temperature: -40°F to 176°F
Maximum Series Fuse Rating: 15A
Certifications: CE, ISO
Maximum System Voltage: 600V DC (UL)
Weight: 14.1lbs/6.4kg
Dimensions: 41.8 x 20.9 x1.4 in
100 watt panels with info and free shipping are available off Amazon for less than $100.
Here's an example claiming to use high efficency cells, $80 delivered;
https://www.amazon.com/JJN-Monocrystalline-Efficiency-Battery-Caravan/dp/B09V4ZDJTJ/
Spec's;100w Panel Solar Specifications
- Module Type: JJN100D-36-M6
- Maximum Power: 100W
- Open-Circuit Voltage (Voc): 24.3 V
- Short-Circuit Current (Isc): 5.21 A
- Optimum Operating Voltage (Vmp): 20.4 V
- Optimum Operating Current (Imp): 4.91 A
- Maximum System Voltage: 600VDC UL
- Maximum Series Fuse Rating: 15 A
It will also use connectors designed to be used out side;
Without Specs, just assume the VOC is too high to do 4 in series, and do 2 in series and 2 in parallel. I think they use auto connectors, you can build your own 'Y' connectors, Do your best to make them water proof and shade/hide them under the panels.
Yes, any future solar panel purchase will be of a higher quality brand. But i I have 6 of the harbor freight 100 watt ones that seem to be working fine. I will do as you said and probably do 2 sets of 2 in series the parallel them together. I believe that would be the correct way.
I usually make this type of post for others who might be following the thread.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 651 Solar Water Pumping
- 608 Discussion Forums/Café
