2 inverters
ws9876
Solar Expert Posts: 453 ✭✭✭
Some people have 2 different size inverters on 1 battery bank and that works ok. But can you take the AC output from both and tie them together so you can use the same romex system? (separate from any grid system).....I would think the current would go out of the active inverter and run up into the in active inverter..but I don't know...whats up with that?
NO!
The inverters would have to sync. You could attach them to an excision device and use the same cable from there on.
Depending on your voltage and wattage, something as simple as a toggle switch to a generator transfer switch.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
https://www.amazon.com/dp/B09XGYB2BY/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B09XGYB2BY&pd_rd_w=MAp9h&content-id=amzn1.sym.3309c9d3-bf37-499a-888c-9ce693c3483f&pf_rd_p=3309c9d3-bf37-499a-888c-9ce693c3483f&pf_rd_r=WNS4TJWRTKN4KWQR83YT&pd_rd_wg=xyWur&pd_rd_r=f1033b6b-917f-49e7-9dec-d17c6b972838&s=sporting-goods&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM
like this...a fraction of the cost of a Blue Seas -
There's a reason it's a fraction of the cost. It's not DC rated and only rated for 63 amps.
This would be on the AC side of things, but I know nothing about it...littleharbor2 said:There's a reason it's a fraction of the cost. It's not DC rated and only rated for 63 amps.
My mistake. Apologies to you.Photowhit said:
This would be on the AC side of things, but I know nothing about it...littleharbor2 said:There's a reason it's a fraction of the cost. It's not DC rated and only rated for 63 amps.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
- 230 Forum & Website
