Eco-Worthy 60A 12/24 solar charge controler
Hondo
Hondo Registered Users Posts: 2
 how do you know when battery bank is full+ Display shows power going into batter but nothing going to light
    Photowhit Solar Expert Posts: 6,024 ✭✭✭✭✭
    Sounds like it has a Battery and Load connections. If nothing is connected to the load I would assume that is the light bulb indicator. In general, nothing but small DC loads should be connected to it.
    The charge controller should go through cycles Bulk, absorb, float for lead acid batteries. Did you set it up for your battery type? Sealed, Flooded, Lithium...?
  • Hondo
    My 24v Off Grid is eight 120w Panels  into a 4 string container onto 60A  Charger Controler onto a 4 12v series conected battery bank and a 3000w inverter. Battery Charger Display shows  solar >>>>> going intp battery       to bulb
    Bulk                           26.4  v
    24v                                                LI
    A photo might help, really this post sounds confusing.
