float switch not working
gregapex
Registered Users Posts: 9 ✭✭
I have a float switch. https://www.amazon.com/dp/B07PXFPPMM?psc=1&ref=ppx_yo2ov_dt_b_product_details. I am running it 260’ to my well pump with 18/3 sensor wire. It's not turning off the pump when tank is full. What am I doing wrong and/or what device do I need to install to increase the voltage over that distance, if that is in fact the problem.
thank you
According to Amazon this is a 4 to 20 mA device, meaning that it changes it's resistance to adjust current flow to signal to compatible 4 to 20 mA equipment (i.e. it would work something like allowing 4mA when empty and 20 mA when full or vice versa). You may have it hooked up as a simple float switch (ie zero resistance closed to infinite resistance open) which may explain why it's not working.
Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries (with integrated heating), Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
- 230 Forum & Website
