Battery Temp Sensor
jACKr
Registered Users Posts: 16 ✭✭
Aloha!
anyone know if any Battery Temp Sensor will work on any brand inverter?
I have a Trace I'm hoping to use on Outback.
I can change the RJ plug if necessary.
Mahalo
jACKr
Mahalo
jACKr
Hi Jack,
I believe that the Trace/Xantrex and OB sensors are both 10 K Ohm, at 25X (77F) Negative Temp Coefficient (NTC) Thermistors, and are wired similarly.
There should be no harm in trying the Trace on an OB CC, or inverter. If the sensor was warm, and the charger was charging in Abosrb, or in Float, and you plugged in, the sensor, the charge/float voltage should be reduced. Or, of course, if the sensor was cold, when plugged in, the voltage to the battery should rise.
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
- 232 Forum & Website
