Kyocera KC167G
fyfchu
Registered Users Posts: 1 ✭
We are looking for ONE Kyocera KC167G. One of the panels in our 24 panel, 18 year old system is dead. We have had no luck looking on line for a panel. Any leads?
Not any fun hunting for older compatible panels. If it's not broken, might try to figure out what is wrong with it, often a connection.fyfchu said:We are looking for ONE Kyocera KC167G. One of the panels in our 24 panel, 18 year old system is dead. We have had no luck looking on line for a panel. Any leads?
Your panel specs:
https://www.pvxchange.com/Solar-Modules/Kyocera/KC167G-2_1-2100023Electrical DataNominal Power (Wp): 167Current at MPP (A): 7.2Short Circuit Current (A): 8Voltage at MPP (V): 23.2Open Circuit Voltage (V): 28.9Max. Reverse Current (A): 0Max. System Voltage IEC (V): 750Max. System Voltage UL (V): 0Temp. Coefficient Nominal Power (%/K): -0.44Mechanical Data & DesignLength (mm): 1290Width (mm): 990Height (mm): 36Weight (kg): 16Bypass Diodes yesDepth incl. Backrails/ Connection Box (mm): 56Cable Cross Section (mm²): 3.5
Can you tell us how your solar array is configured (i.e., 4 series * 6 parallel or 12s * 2p, or what).
For series connected panels, we want to match Imp within 10% (current)
For parallel connected strings we want to match Vmp of the string within 10% (voltage)
And then see what may be able to match to your existing array.
Might also be good to understand what type of system this is?fyfchu said:We are looking for ONE Kyocera KC167G. One of the panels in our 24 panel, 18 year old system is dead. We have had no luck looking on line for a panel. Any leads?
18 years ago there weren't many grid tied systems, yet this appears to be designed for grid tie, maybe 12 in series to have high enough voltage to sync through an inverter....Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
