Remarkable battery voltage disparity?
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Early morning voltage of one is 10.9V. The adjacent, in series, battery reads 12.9V.
The overall series reading is ~49.4V in early AM due to running multiple freezers. The rest of the batteries read ~ 12.4V. I've never seen one battery read so high in the early morning hours (6am) and it is next to a battery that reads extremely low.
The early morning reading of 12.9v surprises me most assuming that readings were taken before any solar production.Without more info, my first guess is that the 10.9v battery is presenting zero load during the charging period, resulting in a much higher than normal voltage on the next one. In my experience, that 12.9v standing voltage remaining overnight would normally indicate serious overcharging. What batteries are these?I always have more questions than answers. That's the nature of life.
Sounds like these 12 volt batteries are in some sort of series configuration, allowing you to take individual voltage readings. Like Mark said one battery is being overworked to compensate for the lazy battery's shortcomings. Average voltage between the two being something like the full bank's voltage.
