Magnun MMS1012 only delivers 8 AMPS when charging
The MMS1012 in my system will only output 8 AMPS when charging. Would original show 30A. I've checked and rechecked all the settings but still can't get but 8 Amps. Any information would be extremely helpful.
    Welcome to the forum Billnax,
    I don't have anything specific to answer... I would suggest starting with the basics. Use a good quality DMM and measure voltages at the inverter (DC battery bus terminals), AC input/output terminals, under load, and idling.
    It is not unusual to find loose or dirty connections.
  • boB
    boB Solar Expert Posts: 1,032 ✭✭✭✭
    Are you sure that the charge cycle is not in Absorb or Float ?
