Trace SW5548- Question about wiring AC side of the inverter
"Knowing is not enough, we must apply. Willing is not enough, we must do." Goethe
2006 Trace Xantrex power panel, (3) SW5548 inverters- 2 NOS Trace's (1999) and 1 Trace/Xantrex 2006 for back up (came with power panel. et al), Xantrex DC/disconnect, Xantrex AC disconnect/bypass, (3) C40 PWM charge controllers- 2 NOS, one used. (8)Evergreen Solar 120w (960w), 8k LG Neon 2, (25) 320w, Bergey XL.1 1.5k genny, Air X 400 genny (came with used system), 48v Interstate Workman batts (now frozen/toast), (2) Montana Solar adjustable Top of Pole 12 array racks, (2) Midnite Solar MSPV 4 combiner boxes, (2) Midnite Solar Classic 150's (one an SL), SOK LiFePo stack of 500ah and one nice Ozark hilltop to set them all on.
Lee, I'll give you a call later this eve.
Ok, after talking to Littleharbor2 today, I need to correct something. There is no ground running between the inverters and the AC Disconnect box. I've been running so much wiring on the panel that I was thinking I'd run all four to this spot, too, but after talking to MIke and re-checking the manual (the panel and wiring is 32 miles away from home), I see there are only the two hot legs and a neutral for each inverter. Also, I called the black wire a common, which is what I, in my ignorance of some electrical work, usually call the second hot leg from a system. Oops. But there are 3 wires running from the inverters to the AC disconnect. Thanks, Mike!
