Combox Missing Power
Ganglefang
Ganglefang Registered Users Posts: 28 ✭✭
The power into my inverter does not equal the power out of my inverter, at least according to the Combox. I can get 2000 in from the grid and 4000 from the solar array, with a load of only 5000 -- Missing 1000W. I had this problem several years ago (2016?) and had quite a discussion on some blog, but in the end I solved it by purchasing a new Combox and SCP. If you have any suggestions for how to troubleshoot this problem short of buying new components which are discontinued, I would appreciate your input. (Yeah, I Know, update the firmware.)
“On grid”
Went live on or about 6/24/15.
Conext XW+ 6848 Inverter SN M70012350
Xantrex XW 80 600 MPPT Battery Charge Regulators
       MPPT(0) SN ZX1428012759 FGA 865-1032 Working 20200908
       MPPT(2) SN ZX1428018533 FGA 865-1032 WORKING 20160829
Conext COMBOX FGA 865-1068 connected to the local network (LAN)
Conext Battery Monitor SN B13068997 Build 4/15/2015
24xRoof Mounted REC 255W panels
Conext SCP System Control Panel FGA 865-2060 SN B13284530 Manufactured May 25, 2016 V02.01.00-0008
  • Wheelman55
    Wheelman55 Registered Users Posts: 281 ✭✭✭
    Ganglefang. I have a “new in box” combox. I purchased this new a couple of years ago and never installed it.
    If you are interested in it let me know.
    Off-Grid in Terlingua, TX
    5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 650ah LiFeP04 battery bank - 5 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries
