Trace SWI stacking cable question
littleharbor2
Solar Expert Posts: 2,186 ✭✭✭✭✭
Trying to add a diagram but it wont take.
Maybe somebody out there has a parallel stacking cable and can get a picture of it.
Did you search the forum here? I threw out all of my info as it is just too old of electronics. I remember seeing stuff about it somewhere."we go where power lines don't" Sierra Nevada mountain area
Ya Dave. I've brought up the subject here before. Been through all those threads again. I need just specific info as to what separates the series cables from the parallel. I can build it now with that tidbit of info.Dave Angelini said:Did you search the forum here? I threw out all of my info as it is just too old of electronics. I remember seeing stuff about it somewhere.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
Around 3 years ago, Dave posted this from this thread:
https://forum.solar-electric.com/discussion/354790/need-part-numbers-or-way-to-identify-series-or-parallel-stacking-cable-for-trace-sw-inverters
The link looks to be still good...Dave Angelini said:This might help from one of my colleagues. let me know if you need more. Stay cool!
https://millersolar.com/MillerSolar/Resources/Xantrex/_xantrex.html
Post a screenshot of the SWI Stacking Cable (for posterity):
RCinFla also posted information (may be the same--I did not trace each wire):
https://forum.solar-electric.com/discussion/23437/need-trace-sw-series-4024-stacking-cable-isc-s-975-0059-01-01-rev-a
And a possible technical source (2015).
And FYI... I use the "site:" tag to limit searches to one website... Works with many search engines, the results for above were in DuckDuckgo:- site:forum.solar-electric.com/discussion Trace SWI stacking cable
Bill, Thanks again for taking the time to research this topic. While I've yet to figure out the difference between the SWI and SWI/PAR cables
I have, while rereading all associated previous posts I have realized that for parallel operation I would need the Paralleling Interface Module to pull this off. I have handled lots of old Trace/Xantrex equipment before and haven't come across the Interface module or I would have ended up with one. I guess at this point I'll put this thread to rest.
I really appreciate everybody's help With this, Mike McCormick2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
