pump distance below static water level
andyrud
Solar Expert Posts: 70 ✭✭
My well recovers greater than 30GPM. I am going to pump 5GPM. The well is 300 feet deep but the static water level is 85 feet from surface. What level below the static level should the pump be set? It seems to me that the seals on the pump would be tested more if the pump was close to the bottom. Where should I place the pump level at using these numbers?
Thanks in advance,
Andy R
Thanks in advance,
Andy R
What brand/model of pump do you have?
In times pasts, I have seen a maximum water depth in some specifications.
BB. said:What brand/model of pump do you have?
-Bill -
Why don't you simply call them and ask what the maximum underwater depth is? Make sure they understand you're not asking about the maximum head.
I took a quick look around and could not find that specification....
A quick call to their 800 number should give you an answer.
mike_s said:Why don't you simply call them and ask what the maximum underwater depth is? Make sure they understand you're not asking about the maximum head.It's more of a question asking if you are using any manufacturer's pump. Is there a logical level to place the pump given the above numbers? My well guy said to put it 20 feet from bottom of well. That seems to me it puts more pressure on the pump seals than it would if the pump was say at 15 feet below the static water level since only 5gpm will be pumped and the well produces 30 gpm. I am not sure what pump I am going to use. I am in the exploring faze right now.
No well expert, but how far down was the water in the well when pumping 30 gmp?
Besides how deep the water level goes when pumping (5 gmp or whatever), you have variations in level during seasons, total water pumping per day, droughts, and when your new next door tenant/neighbor is a pot farm.
Friend of a friend's well went dry when a pot farm moved in and started serious pumping. New/second well went dry and having to drill deeper.
Hope for the best, prepare for the worst....
BB. said:No well expert, but how far down was the water in the well when pumping 30 gmp?
Thanks Bill and all for the info,
Andy R -
You are very welcome Andy.
You still need to know how deep below the water surface the mother and pump can be installed. You are probably correct in needing to know the maximum depth so the seals and gaskets don't fail (from over preassure).
BB. said:You are very welcome Andy.
Andy -
I have basically the same depth well and considering a RPS 400 pump. My static level is 85. How did this work out for you Andy?
I have a solar 1/4hp 24 vdc pump at 70 feet in my well and a 2 hp pump at 220'. upper runs on 2 solar panels for 14k gallons fire suppression and bottom for pressure tank and potable water. Bottom pump also on solar at 220vac.
- 611 Discussion Forums/Café
