Excess production
Ako
Registered Users Posts: 184 ✭✭
This is more of a general interest question , if a solar system produced 4 kw daily and the consumption is only 3 kw then what happens to the extra produced . I know some is used on Equipment , Charge Controllers , Inverters Etc and some natural loss from the batteries but i dont think that would account for 25% in my case a KW each day , the batteries are AGM and new , the equipment is Victron and also new , all the settings and operation of the Charge Controller is correct and as i would expect , im taking these figures from Victrons VRM Historical Data which shows the daily production and Consumption .
2240 Watt Array 4 x 460 Watt Mono Panels + 2 x 200 Watt Panels
Victron Smart 150-70 MPPT Charge Controller
24 volt Battery Bank 4 x 6v 400 Amp/Hr Trojan L16 AGM
LiFePO4 Lithium 100 Amp/Hr Battery for Backup
Victron 1600w Multiplus Compact Inverter/Charger
DC to DC Charger ( Non Isolated )
It is simply unused.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
Then am i right in thinking that the most that can be produced the following day couldn't be more than the amount consumed the previous day plus natural battery loss and the loss through equipment efficiency2240 Watt Array 4 x 460 Watt Mono Panels + 2 x 200 Watt Panels
DC to DC Charger ( Non Isolated ) -
And the energy you use that day of course! This time of year it is hard to use it all offgrid if you are sized for winter!
It is the cost of sizing and reducing genset time offgrid. Some of the good locations for sun do not need a generator ☺"we go where power lines don't" Sierra Nevada mountain area
