SMA SWR 2500U -- EEPROM Error Fault
bnes`
Registered Users Posts: 7 ✭✭
Does anyone have a circuit diagram for the Sunny Boy SMA SWR 2500U ? Or a labeled interior photo?
I'd like to locate the EEPROM.
This is likely related to error from the manual "F-EEPROM dBh : EEPROM cannot be read or written on".
I know where the EPROM is, that's different.
Do you have the ability to reprogram your system?
It may re-write the EEPROM with "good data".
Rewrite with "good data"?
Do you have instructions?
I don't have anything beyond the unit itself, disassembled.
SMA says
https://service-sma.force.com/customer/s/article/Message-EEPROM?language=en_US<div><b>Description</b></div><div>The message is caused by a transmission error during the reading or writing of data from the EEPROM (Electrically Erasable Programmable Read-Only Memory).</div><div><b>Corrective Measure</b><br></div><div>If the message occurs sporadically, it is an internal data backup routine and has no impact on the performance and data of the inverter.</div><div>However, if the message occurs permanently, please contact your installer for further investigation and refer to this article.</div>
The EEPROM appears to be a separate part, an 24C04 from Atmel. This is surface mount, and older technology so relatively easy to change:
The main board is SMA part number 40-46056, with service manual SMA SB2500U-11:EE2001 for the SMA 2500U series and beyond. The software however appears long discontinued Windows based EXE stuff.
Does anyone have experience with a "hard reset" procedure that may clear the EEPROM,
or experience soldering in a blank Atmel 24C04N on these models? -
I replaced the Atmel 24C04 part. There is no change in behavior.
The old windows based programming tools looked too daunting to try, especially without a clear EEPROM reset procedure.
- 621 Discussion Forums/Café
