MT50 with Two Controllers
somesom
somesom Registered Users Posts: 1
I have two solar systems feeding one 12v lithium 200a/h battery.  can I successfully use one MT50 to monitor the battery?
Mainly what I want to do is know the SOC (how much more power is left).  I think with one MT50 on one controller I will not know the power coming in from the other controller. so SOC will be unknown.  What or how do I monitor SOC?
I have 200 watts 24 volts solar into an Epever charge controller - times two (two identical panel/controller systems feeding into the battery).
  • littleharbor2
    You need a shunt based monitor to count all current going into AND out of your battery. There's Bogart Trimetric, Victron and others. Without a shunt it's hard to judge the state of charge based on voltage alone.
    As LittleHarbor says... Shunt based battery monitors--You can get some nice ones from our host:
    https://www.solar-electric.com/victron-energy-bmv-712-smart-battery-monitor.html
    And if you want to try something less expensive, there are a surprising number of battery monitors in Amazon and other places:
    https://www.amazon.com/battery-monitor/s?k=battery+monitor
