Tracer 3210AN
fares
Registered Users Posts: 2 ✭
Hello,
I have 3 solar panel with:
320 w,
Voc 44.87V,
Isc 9.32A,
Vmp 37.08V,
Imp 8.36A
And a mppt TRACER 3210 AN.
Can i connect the in series or parallel??
The 10 in 3210AN signifies it is a 100v controller. Note that according to page 9 of the manual the 100v rating is at "minimum operating temperature" (presumably -25C according to page 25), and at +25C it is rated at 92v.In series the panels would have a Voc of 134.61v. It is common to include 20% margin which would be 161.5v, way more than the 92v/100v the controller is rated for. I would run them in parallel or trade in for a 200v controller.Digression: I assume the battery bank is 24v, or the controller would be brutally overpaneled.
OK Thanks. Is there any controller do you suggest?
I've never bought 200v controller. I know epever (same brand you have) makes some, and Victron, etc.
