pump thermostat
ws9876
Solar Expert Posts: 453 ✭✭✭
Some people install radiators behind their wood stoves to pick up heat. And circulate it with a good pump like a Grundfos or similar to a tank.
If you wanted to turn on/off the circulator pump by thermostat ,what thermostat would you use ?? And how would you wire it to the Grundfos or other pump? It would probably be a drainback reservoir so the pump would go on until the temp got too high in the reservoir. and also would have a second control24 hr timer
so it would only pump during the day..what do you know??
As long as you put a one way check valve in the cold line bottom the het will cycle by itself .
The tank just has to be higher then the stoveOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
You don't even need a check valve, I have a 1" SS loop in my heater, and it themosiphons nicely with a 80 gal DHW tank above the heater. no loss in summer, and 90F water, preheated for my tankless.
( not my system, but very close )
https://www.firespeaking.com/masonry-heaters/heat-water/details-of-plumbing/
We heat a 450 gallon hot tub with a wood fired boiler. No check valve or circulating pump. The difference in height between the 1.5" intake and outlet is about 2 feet.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
You can find a "snap switch" thermostat at a HVAC supply house. They are a disc with 2 spade connectors. Different cycling temperatures are available. If you look in a furnace you'll see them on the outside of the plenum. when the air gets hot enough they turn on the fan. I used one to cycle a fan behind a woodstove until I started using Ecofans.
Meant to write that they are visible on the outside of the heat exchanger, not the cold air plenum.
- 230 Forum & Website
