Underwater Hydropower System? asking for a Friend
My understanding they have:
24V System with 4 trojan
Magnum sine inverter box
Midnite controller
The only off the shelf similar unit I can think of is a sail boat towed water turbine:
https://duckduckgo.com/?q=sail+boat+hydro+turbine&ia=web
You probably need pretty good water speed (something on the order of 5-7 knots or 6-8 MPH) to get them turning out useful energy...
thx
They use to advertise one in Homepower magazine. Can't think of the name of the company, but I know Homepower has their whole article history available online now. You might try checking that out.
"Knowing is not enough, we must apply. Willing is not enough, we must do." Goethe
2006 Trace Xantrex power panel, (3) SW5548 inverters- 2 NOS Trace's (1999) and 1 Trace/Xantrex 2006 for back up (came with power panel. et al), Xantrex DC/disconnect, Xantrex AC disconnect/bypass, (3) C40 PWM charge controllers- 2 NOS, one used. (8)Evergreen Solar 120w (960w), 8k LG Neon 2, (25) 320w, Bergey XL.1 1.5k genny, Air X 400 genny (came with used system), 48v Interstate Workman batts (now frozen/toast), (2) Montana Solar adjustable Top of Pole 12 array racks, (2) Midnite Solar MSPV 4 combiner boxes, (2) Midnite Solar Classic 150's (one an SL), SOK LiFePo stack of 500ah and one nice Ozark hilltop to set them all on.
