MT Solar top of pole lifting bracket- Anybody have the specs (dimensions) on them?
"Knowing is not enough, we must apply. Willing is not enough, we must do." Goethe
2006 Trace Xantrex power panel, (3) SW5548 inverters- 2 NOS Trace's (1999) and 1 Trace/Xantrex 2006 for back up (came with power panel. et al), Xantrex DC/disconnect, Xantrex AC disconnect/bypass, (3) C40 PWM charge controllers- 2 NOS, one used. (8)Evergreen Solar 120w (960w), 8k LG Neon 2, (25) 320w, Bergey XL.1 1.5k genny, Air X 400 genny (came with used system), 48v Interstate Workman batts (now frozen/toast), (2) Montana Solar adjustable Top of Pole 12 array racks, (2) Midnite Solar MSPV 4 combiner boxes, (2) Midnite Solar Classic 150's (one an SL), SOK LiFePo stack of 500ah and one nice Ozark hilltop to set them all on.
FWIW, I ended up fabricating one of these out of 2x2 square tube and an old 1/2" thick picking eye I had laying around. Bought a 4' piece of square tube (I have 5 different sizes in my steel pile, but not 2x2 heavy wall), and welded the eye about 2' above the top of pole elevation (the insert it goes into is 8" deep. And I found out they raised the price to $99, so I'm pretty happy this worked. I think the tube was about $25.
