Off grid backup setup
oil pan 4
It looks like evil energy conglomerate advagrid is likely going to take over the new mexico public regulatory commission.
When advagrid took over Maines public utility they doubled to tripled residential power bills and cut the maintenance budget to save money. Which resulted in more frequent, longer lasting blackouts.
So I have a 24v forklift lead acid battery that holds 6kwh, so it has about 3 kwh useable. No its not 36v. The place I want to put the panels is about 10 degrees south slanted with room for at least 3kw possibly up to 4kw of panels. Not sure what inverter I might use.
I think I will start out running our refrigerator off the setup.
  • waynec
    waynec Registered Users Posts: 22 ✭✭
    edited December 2021 #2
    You might do well to read the post by  onanparts testing the surge capacity of the Midnite DIY hf inverter. I found it very interesting.
    BB. Super Moderators, Administrators Posts: 33,743 admin
    That is a 24 volt @ 250 AH battery bank?
    That would work "well" with an AC inverter in the 600 to 1,250 Watt  range with flooded cell lead acid batteries (basically, max suggested AC inverter is "500 Watts per 100 AH @ 24 volt battery bank rule of thumb).
