PC Fans with 12v Solar Panel
chrishan0111
Registered Users Posts: 1 ✭
I am trying to run 3 x 12v DC PC fans with a 12v 20w panel.
The fan specs are;
Operating voltage: 12v
Max input power: 3.6W
Max input current: 0.3A
and the solar specs are;
DC Voltage: 12V
Open circuit voltage: 22V
Short circuit current: 1.21A
Voltage at power max: 17.4V
Current at power max: 1.16A
First of all, would the 12v 20w panel be enough to run 3 of the fans?
Also, I am just worried the high open circuit voltage & voltage at power max would damage the fan.
Do I need to add something else (like solar controller) in between to prevent damaging the fans?
Thank you for your help in advance!
Chris.
I used a flex panel on my sail boat to vent it 12 month of the year .I thin the panel was 35watts it would even run with the tarp covered in snow.
My worked for everOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Some brushless DC fans will not start with a slowly ramping voltage, some have automatic restart circuit. You will just have to test it and see. If they were my fans, I'd get a 14V 50W zener diode & heat sink and wire it in, to clip the panel voltage on the sunniest days
- 228 Forum & Website
- 618 Discussion Forums/Café
