Possible to ac couple Schneider battery inverter and solaredge pv inverter?
yakapo7
Registered Users Posts: 27 ✭✭
Schneider Electric Conext SW 4048 3,800 Watts, 48VDC Inverter/Charger
SolarEdge 3800H PV inverter
Can these inverters work together?
Edit
why not use the storedge? I have to buy $5,000 10kwh batteries for that inverter. I have already built lifepo4 batteries.
Edit
Easier if you state what you want to do? CSW can't sell roger?"we go where power lines don't" Sierra Nevada mountain area
I want to connect to the grid and offset energy use and run meter backwards during the day using solar.Dave Angelini said:Easier if you state what you want to do? CSW can't sell roger?Then I want to be able to have backup power when the grid goes down
