Possible to ac couple Schneider battery inverter and solaredge pv inverter?
yakapo7
yakapo7 Registered Users Posts: 27 ✭✭
Schneider Electric Conext SW 4048 3,800 Watts, 48VDC Inverter/Charger
SolarEdge 3800H PV inverter
Can these inverters work together?
Edit
why not use the storedge?  I have to buy $5,000 10kwh batteries for that inverter.  I have already built lifepo4 batteries.
    Dave Angelini Solar Expert Posts: 7,057 ✭✭✭✭✭✭
    Easier if you state what you want to do?  CSW can't sell roger?
  • yakapo7
    I want to connect to the grid and offset energy use and run meter backwards during the day using solar.
    Then I want to be able to have backup power when the grid goes down
