XW6848 Firmware
Frankie1967
Registered Users Posts: 1 ✭
During XW6848 firmware download the screen went off, I disconnect and re-connect the power from inverter but don’t work.
Use a PC or Laptop to access
- Version: v1.12 |
Build number: 450
He also should have seen the warning about XW firmware causing XW output to go out during firmare.
This usually causes the modem to go down offgrid. If on grid, or off, the AC bypass should be used to keep the modem alive during firmware."we go where power lines don't" Sierra Nevada mountain area
