XW6848 Firmware
Frankie1967
Frankie1967 Registered Users Posts: 1
During XW6848 firmware download the screen went off, I disconnect and re-connect the power from inverter but don’t work.
  • srivera37
    srivera37 Registered Users Posts: 1
    Use a PC or Laptop to access
    • Version: v1.12 |
    • Build number: 450
    You wont see the inverter, you will see an icon and it show boot loader. That is the inverter and all you have to do is update de firmware.
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,110 ✭✭✭✭✭✭
    He also should have seen the warning about XW firmware causing XW output to go out during firmare.
     This usually causes the modem to go down offgrid. If on grid, or off, the AC bypass should be used to keep the modem alive during firmware.
    E-mail offgridsolar@sti.net
