Float switch bypass
bbbuddy
Solar Expert Posts: 135 ✭✭✭
I'm installing a Grundfos sqflex pump, io101, cu200, and float switch, but I'm having trouble envisioning how to bypass the float switch to keep the pump running when my 3,000 gallon gravity water tank is full. I want to use the pump by closing an inlet valve to the tank and irrigate using the pump pressure/water flow to an irrigation system.
My old brain is having trouble with the wiring bypass, I thought the float switch just sent a small electrical signal to the cu200, but in watching a float switch video it seems the entire pump load is sent through the float switch wires? I don't have it in hand with directions.
I had thought I could use a breaker to cut off the float switch when I don't need it. Will the pump then keep running?
Magnum4024PAE, 2 Midnite Classic 150s, 3100watts solar, 432ah lifepo4 battery. Off grid since 2004.
I don’t think it could run the power thru the float switch ?The wires for the well are 10g it would be a expensive switch if It did that , and you would not need the cu200 if that was the case you could just run the switch in the power cable ?
I’m thinking the pump switch must be powered in the down position so a breaker in the float cable should work .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
There you go
Thank you, the float switch explanation I saw was W.R.O.N.G.Magnum4024PAE, 2 Midnite Classic 150s, 3100watts solar, 432ah lifepo4 battery. Off grid since 2004.
👍 good luck with your projectOut back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
- 230 Forum & Website
