MT50 RPP break
verneri
Registered Users Posts: 1 ✭
Hi guys, total newbie asking for advice. Any advice would be helpful. So, my MT50 gives the error RPP Break - however it works. Should I be worried? Can I keep using it or replace it?
RPP break. MOSFT failure for reverse polarity protection1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
