Series/parallel battery bank.
Question guys,
Given this situation, the owner has agreed for me to rewire the bank. I am wondering if all the interconnect cables (between batteries) can be#2/0 awg, as well as the runs to the buss bars. The final home runs would be 4/0. The reason I ask is that I need to replace every cable and I can’t make up #4/0, but I can make up 2/0. I have enough 4/0 with lugs to make the home runs.
Thanks,
PS. Speaking of Amana fridges, I saw an ad on Craigslist a few days ago looking for some help with an “Enema” fridge. Not sure that that is? -
2/0 is good for 145-195 Amps depending on insulation type in conduit (using the basic NEC chart):
https://lugsdirect.com/WireCurrentAmpacitiesNEC-Table-301-16.htm
Is this with the existing battery bank or something new/different (cleaning connections vs new/different)?
If you are rewiring the existing batteries--Probably should be taking voltage and SG readings (logged in notebook) to see if they are even worth rewiring (time and money on your side).
Perhaps even take 1/3rd of the existing batteries at a time and charging them separately (6/12/24 volt, depending on what chargers you have available) on grid (take 24 hours or more to bring up and EQ?).
Sorry for the delay in replying. Been a lot on my plate off late. I am going to use the original 4/0 and simply make up a few new ones. I found a guy who had some 4/0 and lugs.
T
