Wind Turbine when not in use
TheRue
Registered Users Posts: 2 ✭
Hello everyone and good morning. Quick inquiry about wind turbines... If I am not going to be on my property for a few weeks at a time, and will only be using the power when I am there, what does one do about the wind turbine system during an extended absence? I wouldn't want to ruin the system be leaving it constantly running, charging or hooked up. Thank you all in advance.
I'd use something like a rope, or volleyball net to snag the blades and prevent it from spinning.
Some turbines allow for shorting all outputs and the heavy load stalls the prop. But only apply when stopped - slamming the electric brake on while spinning will result in something broken
I just engage the "dump" function on mine. It has a Midnitesolar 250 Classic controller and a MidniteClipper, so it's easy. Engaging the shorting type "brake" turns the turbine and cable to controller into a heater. Works, but could cook the works.
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
