Experience with AIMS Power LiPo Batteries
CleverJay
Registered Users Posts: 4 ✭
Does anyone have experience with AIMS Power 24v 300Ah LiPo Batts? AIMS are quite a bit less expensive than the equivalent Batts from SimpliPhi and Renology. I wonder if there is a quality difference before I buy. Thanks in Advance.
Welcome to the forum
Posting a link to the batteries would be helpful because my guess is that they won't be LiPo but rather LiFePo4, the latter being the safest chemistry in the lithium family.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 230 Forum & Website
