Aux Port Connector for Schneider Conext 5548 XW+
1daveman
Registered Users Posts: 4 ✭
I installed my 5548 XW+ system a few months ago, and now want to plug into the Aux port to activate some relays for a radiant floor system. I misplaced the connector that plugs into the Aux Port, and have been unable to locate one. Schneider does not respond to my service requests and the company I purchased the inverter has not been able to get me one.
Does anyone either have one of these that are not being used, or know where I could find one? It is a small green 5 pin connector. I expect most people who install these inverters don't use the aux port and so would not need this connector. I would be willing to purchase one from anyone and of course pay shipping.
I would appreciate any help anyone can provide.
Welcome to the forum Dave,
You are welcome to post a photo of the conector here... That may help to identify the connector.
Doing image searches on the web--You can get lucky:
https://duckduckgo.com/?q=green+electrical+connector+5+positipon&iax=images&ia=images
Thanks Bill
I appreciate you taking the time to comment. I have been searching online but so far no luck.
Attached is a photo of where this connector plugs in. I hope this helps someone identify if they have one of these sitting around.
I am trying to get Schneider to send me one but so far they have been non responsive.
Thanks againDave -
Near as I can tell, it appears to be this connector. Search for the phrase and you will find it on Ebay, Amazon, Aliexpress, etc.:
5pin/way Pitch 3.5mm Screw Terminal Block Connector Green Pluggable Type
https://www.amazon.com/Pitch-Terminal-Connector-Pluggable-straight-pin/dp/B00L33Q7CS
https://www.amazon.com/5-08mm-Terminal-Connector-Pluggable-Straight/dp/B00L22OAZ6
Could not find a specific vendor--Appears to be cloned out of China by multiple vendors?
Wow! How the heck did you find that? That really looks correct. I have been Google image searching but never found anything that looks that close.
I will order that and see how it fits.
Thanks again -
I think I started with "green 5 connector wire (without " ") on duckduckgo image search (green 5 position connector wire seems to work on Google Image)... And got the "name" from one of the images.
The proper name may be "mini-Phoenix connector" (via Google search just now).
Good luck Dave,
Thanks again BillTake care
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
