Using a flow switch to turn UV water filter on/off
oakleycat
Registered Users Posts: 1 ✭
Hello!
I am having trouble finding much info on this topic. I have a UV water filter installed in my water filtration system in my van and I'd like to use a flow switch to turn it off when there is no water flowing through it. I bought a flow switch on Amazon and have not been able to find any wiring diagrams. Anyone have any ideas on how I could wire it to use it as an on/off switch? Would I need to get a relay?
Flow Switch:
DIGITEN FS-C01 G1/2" Brass Water Flow Switch with Filter 1-30L/min, 0-2A/ 0-220V(AC or DC): Amazon.ca: Industrial & Scientific
Thanks!
Flow Switch:
Thanks!
Welcome to the forum
What are the specifications of the UV water filter? That will determine how it will be wired.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
One thing to be aware of is that fluorescent tube UV disinfectant systems have a warm-up period during which they don't disinfect water. Some systems have a time delay solenoid valve that doesn't let water flow until the lamp has warmed up. LED UV disinfection systems (Accuva for instance) don't have this delay issue. The 12V Accuva system also has a built in water flow sensor which greatly reduces power consumption as it appears you are thinking of doing as well.
Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries (with integrated heating), Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
- 230 Forum & Website
